Hi All,
Does it matter "which way round" you wire an MCB?? in other words, does it matter which you use as load or line side??
If the thing is marked "line" and "load" it would be obvious, same if the terminals were numbered, but most of then have no marking at all..
Reason for asking, is that i would, left to my own devices, wire all fuses or MCB's with the bottom end as line and the top as load, just seems sensible to me, but i have seen some MCB's with terminal markings that mean they are intended to be fed from the top, what you all usually do???? Do they vary??
john...
john...
