Does anyone know of a reasonably priced 15A metal clad switch fuse (single phase),,, I have to wire a compressor through one as it keeps on blowing 13A plug top fuses (1362's).....
I did that in his other unit,,,, this one has a really old fuse panel (seperate iso - no asbestos) and SWA circuitsI have a 32 I think in my unit, but it is IP65 also, I know where I got it from, but can't remember how much.
TBH, a rotary isolator & MCB in a box would be fine, IMHO.
Mind, I have used 2 pole MCB's before now, in an enclosure, but not for machines, gives you overload & isolation!
IF, you can drop in a dedicated radial on a 16, then just fit an iso?
I'v e not priced it yet,,, hence trying to find a source... I'll probably go with an enclosure followed by a rotary isolatorIt also will not comply with the requirements for emergency isolation of energy if it needs to meet that.
However, a rotary iso before or after would be OK to meet that, and this unit would give you the fusing.
If this is a client, have you quoted them?
If not, then the cost is the cost, if they are a business they have to comply with the law, end of.
There's no real need to stick with metal,,,, I'd just like to use couplers to keep it neat...why the severe need to be metal ?
