meter tails
moose man
Aug 8, 2009
510
got to move a cu is it ok to put the meter tails in yt2 surface monted the cu is going inside from outside cabinet about 1.5mtr away from the cut
i will be putiing two 20mm metal conduit through the wall the with two deep boxs
100 by 100 at each side should give some room for the bends i hope
i will be putiing two 20mm metal conduit through the wall the with two deep boxs100 by 100 at each side should give some room for the bends i hope
Not a good idea to have two seperate conduits for tails you could get problems with currents between them.
Thanks for that i will think of some think else to protect cable in the cavaty
might up size the hole to 1" then use some plastic pipe i think that will carry
the tails and the main earth to the cu
Thanks for that batty it is straight up i think i might go with that
sounds good to me
MOOSE
Please remember your DNO maximum length of tails to be protected by their Head fuse, you may ned a fuse switch at the Origin to protect the tails.
Paul
I ask the dno when thay fitted the cut out switch so i dont have to ask them pull the main cut out and thay said 2.5mtr max
that cost the customer
