ianmacd
- Mar 15, 2009
- 3,877
- 0
Hi All
Just looked at a job where they want a fused spur outlet in a garage for an electric garage door. Was looking good as someone had previously extended the ring to 2 new sockets and used a JB within a meter of the new outlet so was going to spur form that. Then I checked out the bonding.
Gas bonding was missing. Apparently had a meter replaced a while ago but it never looks like it was there. The flexible pipe from the meter goes straight into a T piece so I am guessing it will need 2 clamps on each pipe just after the T? No real issue here.
Water is bonded (kinda). Seems to be in 4mm to the stopcock about 8m away (under the floor). The stopcock has been boxed in as part of a fake stud wall with a small flap to get to the tap but there is no way to get to the bonding clamp without ripping the wall apart/down. Can this be left and just noted on the MWC or will it need some major demolition work to get it up to 17th?
The supply is TN-S. I suspect if its a problem with the water bonding they will say leave it and suspect will get someone in to put in a spur unofficially (if you know what I mean).
I was hoping to use this as a backup for my ELECSA assessment (will already have 1 notifiable + EIC and 1 Minor with MWC) so I need to be able to justify any action taken.
Thanks for any advice.
Ian.
Ian.
