i always do ze, ka on any work i do and i note n a minor works or eic where neccessary, wether changing a light fitting, or replacing or adding wiring points etc, cover your ar$e is how i think
like today, emergency fault on light circuit, et to job, find that there is a dead short across live and earth (light bulbs removed) start in lounge and find all wiring ok except 1 cable, go upstairs in to loft a disconnect feed in clears fault on cable in lounge, start removing cables out of upstairs pendants, fault seems to go in to other loft, near bathroom, open other loft space up, trace fault to bathroom shaver. mirror cabinet, disconnect cable to cabinet, and start reconnecting pendants still testing to make sure all clear, i tested the zs of circuit r1r2 of circuit and also incoming ze and ka, now hands up if any of you would have doone that testing to confirm correct connections that youd remade and also issued a cert with those results on, (c/u is crabtree starbreaker, installed jan 08 16th edition, in my opinion id rather spend half an hour checking with meters that i paid loads of money for to do a job, that the circuit is safe when i leave the property knowing that anything happens and that circuit is correctly connected, (oh and lounge light is metal no earth attached to wiring so did that aswell when i refitted the light fitting)
