been on jobs before where they have the little block cable between head and meter. it makes it very hard to stick a temp supply direct into service head when credit meter is off! (the joys of empty council houses).I agree 100% with Andy.Everything before and including the meter is the joint responsibility of the DNO and the supply company.
It is still an offence to interfere with this equipment.
Most DNO and supply companies are flexible in the control of this law, I would just call them and ask for permission, its just a phone call and you may find them very accomodating.
I have through experiance learned however they now prefer to connect to the meter in very short enclosed runs to avoid any tamper with the supply cables.
This may cause a problem when moving the meter from the origin of supply.
i used to end up doing something like this on 70% of jobs.... but just about every one i only had to remove live from head. they have even fitted the isolators and left it with the 6mm still in service head! (usually same bloke)OmgThat just proves what we have suspected all along.ROTFWLROTFWL
Well not all of them are, we have a very clued up member on this very forum!
