MWC or nothing
m4tty
Scaredy cat™
Feb 5, 2009
5,612
If changing like for like (pendant down and fancy fitting up) and the cables were a bit short so extended them by 3" will that require a MWC or not needed as like for like
Cheers
like for like mate,,,,ensure all the lights on the mcb work after you have done it.. and then.....
move on !!!! ;)
Up to your discretion IMHO...
If your rushed.. give it a miss..
If you want to impress the customer with your technical skill and know-how..
give em a cert!
90+% of the time I would probably give it a miss.
Would still do basic polarity, and Zs tests during the change to be sure you don't leave something daft with no earth and a really high resistance joint somewhere down the circuit!
Would still do basic polarity, and Zs tests during the change to be sure you don't leave something daft with no earth and a really high resistance joint somewhere down the circuit! :|
WHich is a good argument for a MWC as why do the tests if you don't record the results.
Hi,If changing like for like (pendant down and fancy fitting up) and the cables were a bit short so extended them by 3" will that require a MWC or not needed as like for like
Cheers
I would disagree that changing a Class II pendant for a Class I 'fancy fitting' is like for like.
