Badfish
- Aug 16, 2010
- 212
- 0
Hi all just wondering if you have any ideas on my problem.I have installed 12 down lights in a kitchen all 230 volt with kosnic 5watt led lamps.On the same circuit are 2 outside light fittings,2 under cabinet lights and 2 wall lights all fed from a Protek 6amp rcbo.All the other lights are fine but the 12 spots will intermediately trip the rcbo, i have re tested the circuit and all is ok with the cables and connections.I have also changed the switches.I then took all the led lamps out and put 230 volt halogens in,this then stopped the tripping.Cool i thought must be the lamps so i then changed all the led's with a fresh batch from the wholesalers, put these in one by one trying them out and all 12 went in with no tripping great problem solved.2 days later got a phone call the lights have tripped the rcbo again.Oh i have also changed the rcbo. ray Does anyone have any ideas.
Many thanks
Iain.
Many thanks
Iain.
