tony.nickalls
Hi, After Electrican changed RCD spilt load consumer from MCB unit 7 years ago ,my house getting occasionally power cut about one every two weeks even since and even on dry day we sometime get power cut when we come home .we rely my neighbour to check in to keep my freezer going !! so this RCD replacement , that tell tale we have problem somewhere around the house ( my house 100 per cent rewired 15 years ago)
I am aware if that there it is 30 amp long single spur from spilt load RCD consumer unit in the house run through inside house into my brick shed and it is just attached to my house (like a garage) that if causing power cut in the house.??
In my brick shed there is small consumer unit of 63amp MCB. and should i have earthing rod in outside ?? or change RCD unit in the shed ??
Look forward to hearing for your help
Tony
Tony
