Neighbour cut out fuse head inside my property UKPN BNO
oberk
Sep 14, 2020
3
Dear Users
I've stumbled across this forum in search of guidance about an dilemma I have regarding old electrical equipment inside my property. After months of talking to UKPN and hours of searching the web I can describe the situation as follows.
I've owned for around 15 years a commercial property which was constructed circa 1950s-60s. It's a single corner-end premises adjoining a set of 8 identical properties. At the time of construction, a metal-clad cut out was installed at the rear of this property and connected to a busbar chamber which supplies neigbouring properties. Over the years these neigbours have had significant building works and some have since had a new supply installed from another mains cable. I myself have a different incoming supply/cut out and do not need this equipment at all. I've left it untouched for years but now need the space it occupies (it's inside a chamber around 1m2 in size). UKPN have been to check the cut out and confirmed it's live. Recently I've had a friend open the busbar chamber and confirm their is one live 3-phase supply, but I'm unsure who it's going to because as it pre-dates UKPN their plans do not have recent records of this.
I contacted UKPN early this year and have had different conclusions since. At first, they told me they will remove the cut out because I am not using, and at their cost. Then I was told they have to establish if neigbhouring properties use it, which they were confused about for a while but eventually concluded they cannot be sure without testing. The latest they've told me is that the installation falls into what's known as a Building Network Operator arrangment i.e. they own the cut out but everything past that they are not interested in. I am confused about this for two reasons: (1) UKPN own standards define a BNO as that of a "Multi-Occupancy Building". I don't share a building with anyone. My neigbhouring properties are separate premises, albeit they may have been owned/managed by one party at the time they were built. (2) The equipment is very old and potentially a safety hazard. I also do not use the power coming through it. Are they saying I am responsible for my neighbours electricity supply?.
I've had informal chats with one neighbour and asked if I could look at his meter/incoming supply. It looks equally old, and the incoming supply appears to have the same metal conduit that exits the chamber in my property. I believe it's his supply but he's indicated he isn''t interested in any work/cost of removing/re-routing if it's confirmed to be his.
UKPN want to charge me hundreds to visit and switch of the main fuse to establish who, if anybody, uses this electricity (there is no isolator inside the busbar). I am reluctant to pay. If it remains there, I can't go ahead with planned internal building works in my premises, but worse still I am stuck with the risk of this thing degrading even more and maybe one day catching fire.
I'm not sure how to progress with this and would welcome any  advice anybody has to offer. Apologies for the long-winded post. It's partly for my benefit too as I continue to make sense of it all.... I'll try to figure out how to attach photos here if I can.
With any luck, here are photos of the cut out and busbar in my property, as well as the incoming supply in a neighbours property that I believe to be coming from the busbar.
https://imgur.com/a/NiOyuqa
Usually the DNO   ( District Network Operator)  have these things stitched up legally .    As you have found , no one wants to pay .   Perhaps you could ask the Ombudsman  for a ruling .
well if a fuse was to be blown in it, id expect DNO will be called by whoever doesnt have power, and they will then discover the issues for access and how daft it is having it there
You say it is live...
But is there actually any power being drawn...?
maybe its just supplying a.n.other box with nothing connected to the other end.. ?
Can you put a clamp meter round the tails to see if or what current is or isn't flowing?
:popcorn
You probably need someone capable of removing a fuse, (and or possibly replacing with an already blow fuse)....
then wait to see if anyone kicks up a stink cuz their supply has stopped working..
and you will then charge them loads of money to access your property regarding a supply that has nothing to do with you.. :innocent
:coat
:popcorn
:coat
I think it’s live...
only because I’ve had someone with a multimeter used on the chamber. Other neighbouring properties have had their supplies cut Off from this chamber years ago, I’m just not sure if any other property still uses it
do you reckon I have reasonable grounds to ask my DNO to replace the cut out at their own cost if it looks worn down enough. This will force them to turn it off and discover if any ones using it. And maybe I can persuade them to just remove/relocate it in the process??
But..    A cable can be live..
with nothing else connected at the other end..
You have only read a Voltage..
what you need to know is there actually any Current flowing?
e.g.  a lamp holder with no bulb in it could be live.. (A voltage)
but is drawing no power (No current flowing)...
The other end of your live cable could be just terminated in a box nextdoor with NOTHING connected to it!
I am guessing this friend who opened it up to test with a "multi-meter" is not an electrician?
Find a local electrician with a clamp-meter to pop round and test it, to see if any current is flowing and to offer their suggestions....
Guinness
