Hi all,
Just been to look at a new timber framed house to give a quote for new electrical installation.
I have wired and rewired many houses, but a timber framed one is new to me.
I have two queries.
Firstly, on the outer walls hich have solid insulation,there is a gap big enough to get cables between the slab (cellotex) type insulation and the inner plasterboard wall surface. Will these cables need to be derated (though they will be in free air and touching the inner surface of the plasterboard) ?.
On the inner stud walls,(100mm between inner plasterboard surfaces) insulation is approx 50mm thick.
Again, does cable need to be derated ?
Second question is about protection of cables in walls.
Will they need to be 50mm from outer surface of plasterboard ? (All circuits will have rcd protection).
Thanks for any advice.
Speedster.
I have two queries.
Speedster.
