New shop build.
Sonor
Apr 17, 2008
42
Hello, I haven't posted here since last July, been busy, busy, busy.
This set of pics is from a shop build that we've almost completed. The building was a "franchise" block on the site of one of our customers. It had six units. The plan was to knock four of the units into one and keep the other two as storage. Work was started even though one of the units was still occupied and the occupant didn't leave until halfway through the build.
The new shop would be a pets and Aqautics shop.
Just after the false ceiling and some of the wall were knocked down:
DSCF0021 | Flickr - Photo Sharing!
This is where the head and mains distribution were located. It was a small staff room at the back, it was used as a smoking room at some point, hence the slightly yellowy nature of the spurs and sockets. The SWA cables supplied sub-boards around the franchise, the majority of which would be cut off. Some of the meters have already been removed:
DSCF0025 | Flickr - Photo Sharing!
Ok, half-way through the build and these two boards are where the old boards were in the previous pic. The false ceiling is gone and so have the walls. The board on the left will be the mains distribution: one for the board on the right and three others left on site. It's 100amps 3ph.
DSCF0032 | Flickr - Photo Sharing!
This pic show the building from one side to the other. The far side used to be a clothes shop, The glass front to the right was where a health food shop was and the pic was taken from where a garden machinery shop used to be. The new boards can be seen on the right, this is where the staff room and toilet used to be. The wall with the boards was cut in half and re-enforce with a second layer of blockwork.
DSCF0034 | Flickr - Photo Sharing!
Where the health food shop used to be. The walls, ceiling and old electrics where ripped out within hours of the previous owners leaving.
DSCF0039 | Flickr - Photo Sharing!
A little bit of improvisation:
DSCF0040 | Flickr - Photo Sharing!
This is where the fish tanks are going. The insulation on over the former entrance to the clothes shop and on the ceiling are to prevent direct sunlight onto the tanks.
DSCF0036 | Flickr - Photo Sharing!
Sockets for the tanks. One socket does the power for heaters and pumps, while the other does the lights. There are ten racks each containing three tanks. All the lighting in the racks will be switched via one isolator. The 3x3 trunking we installed runs around the perimeter of the building on the purling. We then branched out and down the walls in conduit.
DSCF0035 | Flickr - Photo Sharing!
bit of a jump in time. The tanks are in.
DSCF0042 | Flickr - Photo Sharing!
Light fittings. We ran conduit along the purlings and used clicks for connections. The fittings are twin 42Watt PLTE's. The box on the ceiling is the air conditioning/heating system. I thinks it's going to be worked very hard in this building.
DSCF0043 | Flickr - Photo Sharing!
The rest of the shop. The shop fitters have been in and we haven't got the rest of the lights up yet. Always the cart before the horse with this lot.
DSCF0044 | Flickr - Photo Sharing!
Reptile rack. All manner of snakes, gecko's tortoises etc, stored in there with their rather noisy live food on the shelving next to it.
DSCF0048 | Flickr - Photo Sharing!
The animal house, where all the fluffy things live. Including rats.
DSCF0047 | Flickr - Photo Sharing!
Tills and Information desk. Still need to be wired up.
DSCF0050 | Flickr - Photo Sharing!
Thats it for now. more pics to follow and perhaps some with some electrical work in. ROTFWL
Excellent mate - You have been Scoobed. :)
Be interesting to know the full cost of all that, from start to completion.
Thanks. :)
Ok, Next set of pics.
The fuse board area now enclosed in a cupboard:
DSCF0063 | Flickr - Photo Sharing!
Wired up three phase board. We use Schneider boards because of the Isobar system, but there are a few irritations, such as the coiled neutral from the RCBO's to the Neutral bar, they never look tidy and if you have to remove an RCBO from the board, they get snagged on the other cables. They moved the Earth bars to the top, which is good for easy access, except when you have cables coming from the top of course. But where they are is still an improvement.
DSCF0075 | Flickr - Photo Sharing!
Cover on and in the process of being labeled up. Before anyone mentions, the two top left blanks have been sorted. :Blushing
Another little irritation we have with Schneider and Merlin Gerin before them is the fuse board covers not quite lining up with the circuit breaker positions. The top right RCBO's have had to be pulled down a little bit to get the cover to fit around them. Still, it could be worse, we could have gone mental and fitted a Crabtree starbreaker 3ph board. headbang
DSCF0069 | Flickr - Photo Sharing!
Time clock for external lighting, key switches for EMG lighting.
DSCF0076 | Flickr - Photo Sharing!
Cupboard Closed.
DSCF0070 | Flickr - Photo Sharing!
Exterior water features. How do we power so many?
DSCF0065 | Flickr - Photo Sharing!
Hager Orion IP65 box, fill it with sockets, cut a hole in the bottom for leads and attach an isolator so staff can turn all the features off with one switch.
DSCF0072 | Flickr - Photo Sharing!
DSCF0064 | Flickr - Photo Sharing!
Back inside, sockets for computer routers, hubs and the EPOS system.
DSCF0071 | Flickr - Photo Sharing!
Back in the shop and the lighting is fired up. Customer is well pleased with the light levels.
DSCF0061 | Flickr - Photo Sharing!
The occupants of some of the tanks:
DSCF0059 | Flickr - Photo Sharing!
Bearded Dragons. The snakes in the other tanks were hiding, so couldn't get any pics.
DSCF0068 | Flickr - Photo Sharing!
The animal house now occupied.
DSCF0062 | Flickr - Photo Sharing!
And that's it. I'll try to visit this forum more often. :slap
---------- Post Auto-Merged at 18:06 ---------- Previous post was made at 18:03 ----------
I'd rather not go into specifics, but it was in the region of
