EDITED BECAUSE SINCE I FIRST POSTED THIS ANOTHER INSTALLER HAS GOT BACK TO ME
First, thanks to all the experts who contribute to these discussions; I only found this site recently but already have learned loads. I'm considering solar and battery storage.
We use on average about 9kw/h of electricity per day of which 4 is used from about 6pm onwards. This excludes car charging. We're on Octopus Go Faster so have reduced rate electricity from 8.30pm till 1.30am.
We're just north of Newcastle, the house faces a few degrees east of south. It's a small roof but sufficient for 10 panels. The only issue is that until about 9.30am four of the panels would be in full shade from a neighbouring, taller house but completely clear after that.
The way I'm hoping it will work is that during solar generation hours, solar would power the house and divert any excess to the battery. Then outside of those hours the battery would power the house as much as possible but I don't think I'd want it to discharge during our cheap electricity hours, I'd want it to charge at these times.
I've spoken to a number of installers, some say they'll send a quote but never do, others stop communicating when I ask them questions and of course others are just so busy they can't quote and this is fair enough.
So I'm left with a few options from a couple of installers.
INSTALLER ONE
JA Solar Percium 385w panels
Solis S6GR1 3.6kw inverter
A choice of batteries including Alpha, Puredrive, Plylontech in capacities from 5-9kw/h
Total price for SOLAR ONLY (so excluding battery) including installation, bird protection is £6250
He has suggested that the array is wired as two strings to mitigate the shading issue.
My concern with this is the inverter is quite basic, although I appreciate that's not always a bad thing and it only has one MPPT.
The same installer has also given me a quote for an alternative:
Same Panels as above
Solar Edge inverter and optimisers
Givenergy 9.5kw/h battery and inverter
He has quoted an additional £1,100 for the solar only part for the SolarEdge upgrade.
INSTALLER TWO
Eurener 410w panels
Solis RHI 36K-48ES-5G inverter
Puredrive 5kw battery
Overall quote INCLUDING battery, installation and bird protection is £10360
This installer doesn't offer Solar Edge but can offer an Enphase solution for £2300 more.
INSTALLER 3
Hyundai 410w panel
Growatt 6.5kw/h battery
Growatt 3.6kw hybrid inverter
Tigo optimisers
Total cost - 9900 including installation and bird protection
I appreciate that's a lot to read. Would really appreciate any thoughts on the choices offered. I can't compare price wise as mentioned above the first installer has given me choices with regards to battery.
Thank you.
INSTALLER ONE
INSTALLER TWO
Eurener 410w panels
INSTALLER 3
Hyundai 410w panel
Tigo optimisers
Thank you.
