F fellsider Junior Member Joined Apr 12, 2012 Messages 1 Reaction score 0 Apr 12, 2012 #1 I need to move the position of a night storage heater. Is there a maximum distance from the switch that the heater can be fixed?
sparkytim Well-known member Joined Mar 14, 2010 Messages 1,809 Reaction score 1 Apr 12, 2012 #2 No, BUT the switch is a LOCAL means of isolation so should be still under the control of a person working on the heater, and if a longer flex is used should be no longer then required to meet volt drop and or other wiring regs requirements.
ProDave Twatt ™ Supporting Member Joined Nov 28, 2009 Messages 14,681 Reaction score 832 Apr 12, 2012 #3 How far away from the switch do you want it? Don't try and move it with the bricks in. Let it cool down and take the bricks out before moving it. If fitting a new flex, make sure it's heat resistant flex.
Technician Well-known member Joined Sep 26, 2011 Messages 1,446 Reaction score 0 Apr 13, 2012 #4 I read the point about the volt drop and would a live Zs measurement be advisable following the fitting of a longer flex? Would this justify a Minor Works?
Zeespark Gold Member Supporting Member Joined Apr 24, 2008 Messages 3,940 Reaction score 11 Location Viva La Chesterfield, United Kingdom Apr 13, 2012 #5 If a like for like replacement, I would say that an MWC is not needed Tech, but I would do one Myself to make sure My rear end is covered. AndyGuinness
U utterlyfab Active member Joined Mar 22, 2015 Messages 25 Reaction score 0 Location slough Mar 22, 2015 #6 Thanks
ProDave Twatt ™ Supporting Member Joined Nov 28, 2009 Messages 14,681 Reaction score 832 Mar 22, 2015 #7 You are going to pi$$ people off if you carry on making pointless posts.
