Lee Sparks
Hello Chaps,
I got a call today from a property owner who rents a house in Raynes Pk.
Tenants complain about getting little shocks when touching the metal light switches.
I went there today (out of my comfort zone) thought its worth investigating & maybe learning something + they might accept my quote & even be able to do the work myself.
I loosened about 5 switches at various points in the house, at each switch it was wired in a 1.5mm 2 core cable.
No cpc in sight, no fly lead. All light switches are metal.Same story at light fittings, also metal, 2 core.
Fuse board was reasonably old, old MK re-wireable CSU with updated plug in MCB's, No RCD protection.
Now, i was going to quote to re-new the cable with 1.5mm twin & earth, like for like. All accessories are being kept, so basicaly re-wiring the ground floor & 1st floor lighting circuits.
Does the above work need to be "Notifiable" to the LBA, or not?
If so, would it be a EIC?
Currently im not with a self cert scheme, i do plan to join one by the end of this year. But feel i dont have enough experience yet.
Also, did i miss anything, should i have checked on other things? Any feedback is well received.
Thanks!!
Lee.
Thanks!!
Lee.
