Ive got an exam coming up I know before every test I should null the leads to get the correct reading.But what happens when you have got say 4 sockets close together obviously using a plug in tester so you dont take the socket fronts off.Do you have to keep nullin the meter for each of the socket tests or can you just null the meter once before and test the sockets in a row one after other Id like to know which way is correct because one saves time Ryan
