Everyone sould have a clamp meter!
I think you will find a regulation about this very thing.The problem with newly qualified electrician they are not aware of the previous version of the regs and installation methods used, so find it hard to make a call on what is acceptable or not.
i do the same usually, simple things just do them as i go. or if its really bad, then leave them and note everythingSometimes I seem to be alone in that I like to "correct" simple faults as I go along when doing an EICR.
For instance, if I had found a shower cable in the loft that had been covered with an extra layer of insulation when the loft insulation was topped up, providing there was enough slack in the cable I would just lift it up onto the top of the new insulation. Problem solved.
