outdoor cables
gordy71
Jun 29, 2009
235
Just wondering what sort of cables people use for general outdoor wiring, where an swa isnt needed or any mechanical protection?
I like to use a cable called hi-tuff for outdoor use.It's like swa but without the steel in it.
anything UV resistant ie black, which is usually hi-tuff
Just because a cable is ''Black'' binky, doesn't mean it's UV resistant. It's the properties in the make-up of the sheath that will make it UV resistant or not!!
It all depends on what and where your using the outdoor cable, and the environment/position it's installed. ...For argument's sake if its carrying 230v and installed where children, domestic, or wild animals are present then i would certainly stick with the armoured cables. Sheaths can be repaired, where-as living things sometimes can't!!! lol!!!
According to BS7671 2008 it is (but i know what you mean ;)
oh damn so the artic flex with no earth run up our large real christmas tree supplying our 2000 lights in the tree isnt suppose to have been used then, :eek: :popcorn] :) ]:) :innocent :_| :Blushing i mean i only turn the 13amp fuse rated spur with 13amp fuse on twice a year, heats the decking and lawn area a treat :^O :^O
