outdoor lighting
grant g
Mar 11, 2012
hi i need a light in my new gazebo.i have 2 outdoor lights running from a single switch inside the house.
is there anyway i can put a switch in and a light from the existing lighting that's there? if so how is this done ?
i live in cyprus where the wire colors are the same. thanks ......
take a live from the permanent side of the supply, and a neutral from the light and connect thru the switch with the live to go into a switch live continue the neutral to the light and dont fogret any earthing if its a metal fitting hope that helps. :)
That's if it's 3 plated at the outside lights but not if it 2 plated through switch as only switch live will be at light fittings :)
