I mentioned this problem in passing in another thread. Two years ago I fitted a new element to my immersion heater and all was well until three months ago when the water became dangerously hot. I lowered the thermostat setting but was still getting a couple of sinkfuls of scalding water before it quickly ran cold. The cut-out button didn't pop up.
Three months ago British Gas fitted a new thermostat but the problem continued. Then I discovered that the vent had become blocked and that the cylinder had distorted and sprung a seam - presumably because of the excessive heat.
Last Monday British Gas fitted a new cylinder, thermostat and connecting pipework but the water still ran far too hot, even when I lowered the thermostat to 48 degrees. I checked inside the wall switch and there were a couple of loose screws which I tightened. Then the thermostat failed to work at all! The plumber came this evening and said he would fit a new one tomorrow.
In the other thread Kerching commented "I would be v surprised if a faulty switch made it overheat...more chance of a knackered or incorrectly wired stat!".
I've read of bad batches of thermostats, but what are the chances of a two-year-old one and two brand new ones failing. And even I can wire a thermostat with reasonable confidence and the last two were installed by different British Gas fitters. I'm very doubtful that a fourth thermostat in three months will be satisfactory.
And I'm not sure how hot the water has to be before the cut-out pin pops up, but it never has, even though the water was scalding.
Looking forward to your comments!
Moonraker
Moonraker
