monkfish10
Hello,
Moved into a first floor flat house conversion september 2015. Was told by landlord that new fuse box installed 18 months ago and electrics had been tested and inspected. Have had around 6 powercuts over last few months usually around 1 month or so in between - and the latest one, which I will discuss in next paragraph, has me a bit worried. When trying to resolve the powercuts I switch off all plug sockets/unplug everything and flick down all circuit breakers and turn off the mains and wait 1/2hr - 1hr for the fuse box to calm down before flicking them on again. Whenever I flick up the socket circuit breaker switch it ALWAYS causes the main power switch to go down. All the other circuits (lights, smoke alarm, cooker light, doorbell) are fully operational when socket circuit breaker switch is down. It takes several hours or longer for the circuit breaker that feeds the sockets to stop the main switch from tripping and finally stay up which gets everything back to normal
I assume the powercuts are due to crappy or faulty wall wiring and that maybe when there are a lot of appliances running at once an overload occurs due to the weak electrics being unable to cope ? - i'm always careful to make sure that too many things aren't plugged in at once.
HOWEVER, this time had a powercut like always, but when the sockets came back on, the lights went off and wouldn't come back on again. It's been 2 days. Strange thing is that the lights circuit breaker switch, all the other switches and the main switch remain UP!? Read somewhere that a wire could have melted as a side effect of the powercut and/or switching the fuse box on/off causing the lights circuit breaker to become defective? I'm worried that this is a fire risk?
I'm pretty certain a faulty applicance isn't causing the powercuts because I use everything pretty much every day and surely a powercut would happen not long soon after? Landlord suggsted that the heating element in washing machine was originally causing them but had the heating element replaced and powercuts still followed suit. Can't say for sure but I think some of the powercuts have happened when I'm in the kitchen doing washing up running hot water from kitchen tap. Could it be something to do with the boiler or maybe it just contributes to the electrical flow resulting in an overload?
Please can someone suggest what is causing this very annoying problem and offer any advice on how to fix it ! I have an electrician coming round tomorrow but want a heads up so I can explain the situation in more detail.
Thanks, Cal
Thanks, Cal
