Pricing
m4tty
Scaredy cat™
Feb 5, 2009
5,612
Just been round customers house and she wants a price for changing 2 light fittings from pendants to fancy big metal fittings. (1st floor bedrooms)
The ceiling is artexed and the loft above is boarded so I dont know whether the pendants have been wired next to a joist. So i cant tell whether the new fittings can be fixed to the joist.
What do you guys do in this situation. Also would you check Earth continuity at quotation stage?
Cheers
---------- AUTO MERGE Post added at 18:13 ---------- Previous post was at 18:05 ----------
Also this doesnt need to be rcd protected if im just changing like for like. Even though im changing from pendants to metal fittings. Ie, from class 2 pendants not requiring an Earth to metal fittings which do require an Earth. Long day head hurting stupid question sorry
have a poke around above the pendant with a wire while you are still there to get a idea of what you are up against on the day will only take a minute to have a poke around.
I would check for earths at this stage just by looking in the pendant.
I use various plasterboard screw in fixings that seem to work well if you can't get a fixing into a joist.
Some frown on them though, as there's some ruling that a light fitting should be able to support 5Kg or something like that.
However, if it's not a pendant fitting, so unlikely to ever to have to support anything other than it's own weight, then I don't see a problem. I just put several fixings to support it as best I can.
Sf have got fixings called snap toggles, they are fantastic. Though the fancy lights I have fitted have had just one center hook that the light hooks on to. I also have some 1mm handy to tie on to the hook an temp supend the light whilst connecting
  1. Drop pendant, use a long bit & drill up through loft boarding to give a location & look to see if boarding is nailed to joist. Giving indication you have a joist to fix light to.
  2. Drop pendant, use a long bit & drill up through loft boarding to give a location & cut boarding to insert noggin for fitting to be fixed to (fein tool .....oh yes).
  3. Use plasterboard toggle bolts to fix fitting to ceiling (would be my option).
---------- AUTO MERGE Post added at 19:55 ---------- Previous post was at 19:53 ----------
+1 save turning the air blue
