tom1
Distinguished Member
- Aug 7, 2009
- 2,330
- 0
after reading a few threads on here i am not to keen on messing with heating systems. but this WAS a straight forward take off the wall and put back on.
here goes.
this looks exacly like the programmer, cant say if it is the exact same model
its 3 port valve system.
basicaly marked and noted down which wire and terminal. took off and wired back up.
hot water works,
heating light turns on but the boiler or pump dont kick in
it is posible i have mixed a wire up but i dont think i have, spoke to a plumber i know and he says its likely that its an existing fault and the port vlave needs replacing.
will post a pick of the terminals in the programmer when the forum lets me.
its fed L, N, E from FCU and then two 3 core and earth with 1 core just in a terminal block in the back of the box
sorry the info is limited but any advise would be appreciated thanks
here goes.
hot water works,
