Hi All,
I am going to have a new consumer unit fitted as the old is wire fuses and wooden backed (Wylex).
However, as all will be on RCD I am concerned about my fridge/freezer being cut-off if RCD trips. Leading to mushy mess in freezer etc....
Any advice on best way forward most welcome?
Domestic fridge freezer...
in the typical domestic property....???????
advice...
Best way forward is just have it wired in the most economical and convenient way for your home requirements and budget...
and don't get all paranoid about RCD's tripping off on their own and causing irrecoverable damage.
You are more likely to get a power cut than have the RCD trip off for no apparent reason.
Most fridge freezers are happy for several hours without power before any serious defrost sets in...
If RCD's were such high risk issues with freezers then millions of homes would be losing their freezer contents day in day out....
The only people who need dedicated freezer circuits in a domestic environment IMHO are those who also.
always carry an umbrella in case it rains...
always have some sticking plasters in their pocket in case they cut themselves...
always have a spare can of petrol in the car in case they run out of fuel...
always carry two debit cards, three credit cards and cash, just in case one is not working...
always have a back-up generator wired ready to switch in in case of a power cut...
always have several gallons of water stored in plastic tanks in case the water supply goes off..
and keeps several bottles of gas so the camping stove can be used if the gas supply fails.
reconsider the REAL risk, then just wired it like 1000's & 1000's of other properties part of the RCD protected kitchen ring or radial!
Guinness
p.s.
welcome to the forum!
