solar-forum
Active member
Hi. New subscriber and new solar PV user here.
I am trying to understand my power usage subsequent to our recent Solar PV
installation.
We have 12 x QCell Q Peak G9 380w modules (giving a nominal 4.56kW), a Solis
3.6kW RHI inverter and a 5.12kW Fox LV5200 battery installed. The system also
gives us an EPS to power our oil fired boiler, pumps and shower unit in case
of grid power outage.
Prior to installation, our base power usage (as indicated on our smart meter
IHD) was around 200-250 watts. This covers fridges, freezers, various bits of
computer equipment and devices on standby around the home and in the garage. Our
total annual electricity usage has been running at around 4000-4600 kWh per
annum. Daily usage varied from 10-11 kWh in summer to about 15 kWh in the winter
months.
Now according to the solis monitoring system our daily yield is a very healthy
27kWh (well it /is/ sunny) and as a result we are exporting over 1kW for most of
the day, and as much as 3 - 3.5 kW for a sustained 5-6 hour period during peak
sunshine.
Now to my question. According to our meter IHD, we are still consuming between
£0.50 and £0.80 worth of power per day. Assumimg that this figure includes the
daily standing charge (of £0.22 plus vat) that means we are still pulling between
1 and 2 kWh of power from the grid each day. I don't understand this. Given that
we are producing 27 kWh per day, our battery stores 5.2kW and our nightly usage
will be around the baseline (200 watts per hour) why should we be pulling any
power at all at the moment? (I know we will later in the year).
Is it simply the case that the system will always pull some power as it polls
the grid to check whether it is connected? Or is there something else going
on here?
I would be very grateful for any and all advice. Am I missing something obvious?
installation.
months.
sunshine.
on here?
