Evening All I need to connect some door magnets to the above system its the one with everything on a radial with dill switches . In the manual I see it has an Aux 24v supply and I thought you would be able to come out of this into the door magnets . Although the manual says you must run via an external relay and Psu . But I don;t see the point in having the Aux supply if you cannot use it ? Anyone with any info appreciated .
