- Feb 27, 2008
- 11,018
- 0
BlueyHello Guys,All sorted now. Thanks for all the help. found 2 faults in the end. Cooker causing rcd to trip and the kitchen ring. After taking all the sockets off, unable to clear fault, but customer had a new kitchen fitted a couple of years ago and all kitchen was wired in new cable but cables leaving c/u were in older cable. Eventually after taking several kitchen cupboards apart found an original socket near the floor where the "electrician" had connected in the cable for the new sockets. Found cables falling out of this and touching between nutral and earth. Not sure why my ins test didn't find it originally but did today?? Same meter and everything. Thing was with this socket its chased into the wall originally, but instead of chasing the new cable into the wall whoever did it has just run the cable straight out of the top of the socket and screwed the face back on as far is it will go!! On top of this it is directly below a plastic push fit sewage pipe from the washing machine. Didn't have anything to sort it with on the van today so going to move it up the wall a bit and fit a surface mount box with a joint in there as it can't be used as a socket.
So you did not put cooker on Rcbo. I will always put them through Rcbo's or metal conduit. Well done for finding faults.
Batty
