Scenario is a split board, one side standard main 100A switch, the other is RCD protected circuits.
On the rcd side is up & down ring, cooker and shower.
The RCD keeps tripping but only when the dryer is on in the kitchen.
So either it is the dryer or the sockets behind the dryer, as sometimes when you open the back door right next to the dryer it does not trip out when it is on. There is a bit of a rattling noise in the back of the dryer when it is on.
The dryer may work fo like half an hour before the RCD trips, it is never straight away, it always works for a bit.
Am going to have a look later but just wanted some advice first.
My first thoughts are ther is a fault with the dryer?
But could there be an issue with the sockets behind the dryer, like condensation or something like a trapped cable?
There are other things plugged into the 2 double sockets behind the dryer, and an fcu feeding an outside light? But it only trips when the dryer is on.
Any ideas guys on what could be causing the RCD to trip?
