not always, as long as there is no contact between tails and the metal db then there is no risk of a short to earth before the rcd. Use paxolin to insulate between the two. either method is ok, i did a farm last week and the main 300ma rcd went into a plastic enclosure before the installation because there was no neat way to get tails into trunking/board setup correctly.
