- Dec 25, 2011
- 5,460
- 70
Hi, what's the OFFICIAL process for getting a REC isolator fitted? Also any idea of costs for EDF etc to do this. I'm assuming I can supply it / they fit it? Thanks.
Do they give a reason why? By them not allowing it (or making doing so prohibitively expensive) then surely it just encourages people to start breaking seals. IMO an REC can only be a good thing. I assume WPD is a provider in the post above - they sound very fair/reasonable? Also what does "IIRC" stand for?Unless they have changed there policy EDF will not fit isolators.
Cheers for clearing that up! I don't really go in for too much of this "text" speak! Anyway, I've emailed EDF enquiring how to get an REC installed if I supply it. So, will see what they come back with - they quote up to 10 days for a reply!Iirc = if I remember correctly![]()
their responsibility stops at the meter tails, they will say any equipment after that is nothing to do with them, around here the supplier is responsible for new earth connections. So the EDF may be the people to ask as they are a supplier but the DNO may be UKPN. Even the very few meters with isolators around here have had them sealed.Do they give a reason why? By them not allowing it (or making doing so prohibitively expensive) then surely it just encourages people to start breaking seals. IMO an REC can only be a good thing. I assume WPD is a provider in the post above - they sound very fair/reasonable? Also what does "IIRC" stand for?I will call EDF and ask.
Thanks.
