Hello n123999. Guinness
Welcome to the forumbulator!
I honestly don't know exactly what your course syllabus is asking for....
But basic concepts of relays(and/or contactors) and latching on / off shouldn't be that hard!
Also I don't know how much you understand already..
So I shall assume not much.. Ignore any bits you already know..
and ask again for any bit that I miss off or don't explain clear enough.
1/ A relay is just a switch which is operated by an electric current flowing through a coil of wire.
The coil of wire creates a magnetic field pulling the respective switch contacts open or closed via an armature lever mechanism.
2/ Relays can have just a single switch contact or multiple switch contacts,
also can have combinations of make switches / break switches.
3/ If you get your 6v supply and connect it directly to the coil windings of the relay the relay will operate, As long as the voltage stays there the relay will stay operated.
Now your example talks of Push switches:
I am guessing this is to use a 6v simulation to introduce you to the concept of machinery start and stop control gear?????
maybe wrong
no doubt someone will correct me!
So if you have got two push button switches:
1 x Make switch. (normally open contact, closes whilst physically held in)
1 x Break switch. (normally closed contact, opens whilst physically held in)
And if you make up a little circuit:
If you wire from supply to 'Make switch'
then to 'Break switch'
then to relay winding coil
then back to supply.
So long as you have the make switch held in the relay will operate,
but if you let go of the make switch the relay will release.
Now if you have a pair of make contacts on your relay and bring two wires from these contacts, and wire them in parallel with the make switch.
When the make switch is held.
Relay operates.
Relay contacts provide a parallel path to keep the relay held.
when you release the make button the relay keeps itself held "latched" on.
the only way to release the relay would be to remove power OR
press the Break button.
So the make button could be considered a Start / On / Hold button
and the break button could be considered a Stop / Off / Release button.
Other contacts on the relay could be used to switch on a machine or process of some sort...
The above is a simple illustration of a simple relay latching circuit with a
two button on/off arrangement.
An OFF / Stop button is normally used as an emergency stop feature..
ie.
cuts power
relay releases
and wont re-energizes until you re-do the start button!
HTH
Guinness
