Hi all.
I have a standard 500W halogen floodlight mounted under the eves of my 2 story property. I am getting fed up with regularly replacing the blown bulb or the fitting as the terminals burn away due to bad connection with the bulb. The unit is powered via a standard 13A plug in the loft via a remote control stitch so that it can be turned on/off from downstairs.
I have considered replacing the unit with a LED floodlight but when I tried a couple of 50W LED floodlights with the wide spread of light from such units at the height that they are mounted, I am lighting the gardens of the properties on both sides and also the A road that runs at the bottom of my garden whilst failing to get enough light on my property.
Plan B is to fit a 12V 240w transformer in the loft powered as above, and to use the original twin and earth cable (that is buried in the wall) to feed the 12v supply to 4 x 48w Cree LED vehicle spotlights which should produce considerably more light than the original halogen unit whilst being more reliable and also more directional than a standard LED floodlight.
could anyone help with the following queries-
Is this a reasonable idea or will I be breaking any regulations?
Given that there will be losses in the transformer, would this be more efficient than the existing light?
Would the input surge cause any issues?
Thanks in advance for any replies.
