pewter
Conspiracy Theorist™
I am having trouble getting Megger Powersuite Professional Software to work.
my setup: macbook pro retina display, running OSX, parallels 8, windows 7 home premium (in a window)
I managed to install the Megger powersuite software, and register the product key.
when i run the software i am told :
-Data registry is read only'
It then loads for log in. I log in with my computer user name and password. i use the OSX pass word, which is same for windows 7 run in parallels. I assume it is that user name and info as i have not registered any for the Megger software.
i enter my user and password and i am then told-
- Run time error '3704' : Operation is not allowed when the object is closed -
and the megger program then closes.
I got the Megger software free with my tester, it states 30 days support so i will ring them this week.
I download the Easy Cert evaluation version and it works as it should. From everyones advice on here i did plan at a later date to get Easy Cert. I still want to try out the Megger powersuite.
I am assuming there is an issue with windows run in parallels. Any ideas would be appreciated.
