Hi everyone!
I would be really grateful for some broad advice if anyone can spare the time.
I’m planning on building a sauna and steam room (2 separate rooms). I’ve been through the sizing and the sauna would use a 7.8kw heater and the steam generator would be 6kw.
Because it will be in the basement and the whole of the remaining ground floor is block and beam construction, it is possible to pull new cable through under this floor where it is nice and cool, so running in whatever thickness of cable shouldn’t pose the contractor any problems (I’d be happy to get the cable routed with/for them). The run is probably in the region of 10m back to the consumer unit.
Ideally both heaters would be able to be used at the same time so you could go from one room to the other, already heated. I’ve read and kind of understand the diversity thing but I’m considering that when first switched on to warm up, the sauna would be going flat out for maybe 45mins. The steam generator would probably be intermittent (if my visits to the sports centre are anything to go by anyhow) and a session would probably last about 2 hours overall along with heat up.
I’m just wondering if this type of load would be ok along with all the other appliances in the house, we have pretty much all appliances, big amp for tv sound, American fridge and what have you. Also a couple of kids so there are a few big TVs on and computers and what have you.
The consumer unit show a max 100a allowed, I’m not sure about the main fuse as I can’t find the thing to open it and have a look so will have to pick one up. I’m guessing it’ll be 100a also as the consumer unit is from when the house was built so I doubt they would put a 100a one in if the main fuse was 60a as it would probably cost more I’d guess?
I’d be really grateful for general thoughts on this before I call someone out and potentially waste their time. Also, if it sounds feasible, would they need to go on two separate circuits or could they be split from the one? Only ask this as I have just one space left on the CU so might have to consider retiring the electric shower if they need their own (been dying to change to a rain head anyway).
Thanks for looking, hope it’s a straightforward question to those that know and hope I’ve provided sufficient detail.
