I have a few questions regarding a new build and Part P certification.
We hired a contractor for the build, and that contractor had his own electrician (his own son). It was only after the building was "finished" that we had reason to believe that the Part P Certificate was not legal. The situation is as follows:
- The electrician who did the work is not Part P certified, he is not a Competent Person.
- It was this electrician who tested the installation and filled out and signed the EIC. This was three months after we started using the building.
- There were no inspections of the electric installation through building control (our contractor said, and still says, it wasn't necessary)
- The Part P certificate itself was signed by somebody else (who is a Competent Person/Part P certified). This electrician however has never done any work on the installation, has probably never even seen it, and has not signed the EIC. All we have from this electrician is an invoice for £75 (the electrical installation cost over £30K) and his signature on the Part P certificate.
- Two other electricians, both Competent Persons and Part P certified, have deemed the installation dangerous (they found several loose earth cables and even an unterminated live wire). What's more, they were unable to locate one of the circuits that was tested according to the EIC.
- The contractor and the original electrician have been refusing, for over a year, to come back to site and fix the problems. They are also claiming that their test reports and certificates are correct, valid and legal.
Part of the building is commercial, and this situation has cost us a lot of money (without a building certificate, the building is not insurable).
My questions:
1. Is our contractor right in saying that the whole procedure was correct and legal?
2. If it wasn't, how can we prove that it was not? What can we do about it?
3. Is there anything we can do about this electrician who is not a Competent Person? We can't report him to a Competent Persons scheme, because he isn't a member. He has caused us not only a lot of hassle, but also a lot of money (not being able to use the commercial part of the building, costs for other electricians to do tests etc.). Shouldn't he be held responsible to pay for the costs we incurred?
4. What can we do to get financial redress?
My questions:
