- Joined
- Dec 24, 2013
- Messages
- 1,581
- Reaction score
- 339
Which alarm? and the answer will probably be .............no.Can someone please send the engineering code for this alarm to me please? I've moved into the same house with this alarm but don't have the code
I base this on the idea that when an alarm panel is installed the person installing it changes the engineers code to.................something they want, so it is not possible to tell you what the code is.
Your only option is to default it and start again, but then again, if you had to ask that, I have to ask do you know what you are doing? I suggest you get some one in to do it for you........
