I want to reuse my existing security system power supply with my new security system panel. Looking at the labels of both systems, it appears to me that the PRI power is identical while the SEC are different. Based on the info below, can I safely reuse the power supply from my old security system with my new system?
Can someone also explain the SEC and how it would affect my new system? I'm not an electrician just a do-it-yourself kind of guy so any help would be appriciated.
Old System: PRI 120VAC @60Hz 0.30A SEC 16.5VAC@25VA
New System: PRI 120VAC @60Hz 0.30A SEC 9VAC@25VA
Thanks!
Thanks!
