Hi
maybe an admin will move this post in a most appropriate section.
I thought I'll share those links as I have found them useful to calculate how I could mix panels to optimize the space I have available. how to calculate the minimum and maximum numbers of panels per string.
Current Mismatch: (to see how one could mix PV Panels)
This is a support page from Tigo if you know any other please share
https://support.tigoenergy.com/hc/e...xt=You can mix and match,than or equal to 25%
additional info
http://www.diva-portal.se/smash/get/diva2:1249003/FULLTEXT01.pdf
Min and Max String Calculation:
https://solardesignguide.com/calculating-string-size/
Find out Max and Min Mean Temperature:
http://ashrae-meteo.info/v2.0/
Solar Atlas:
https://globalsolaratlas.info/map?c=52.673051,-4.735107,7&s=52.517376,-0.549316&m=site
I have found those pages useful. I am sure there will be many more and some better than this.
Does anyone know if there is a register that lists similar websites?
additional info
Solar Atlas:
