Hi, new to the forum and appreciate any help that is provided.
Recently moved the shed and have access to a mains supply which is approx 6m away. I'd like to run power to the shed for 2 double sockets and 2 small strip lights. Won't be powering anything significant ,few tools or a radio. My issue is that i need to have the supply cable run from the mains board up and over to the shed (15ft up) then down a pole and into the shed. What cable should i look to use for this, swa or is there an alternate? and what size should it be?
Was thinking of a 20amp breaker at the mains board and a 10amp for the sockets and a 6amp for the lights in the shed. Would this need to be increased if i added a 20w led security light?
thanks in advance
thanks in advance
