mcgaw81
- Feb 14, 2008
- 576
- 0
Currently doing an install on a 9.0kw shower. The property is massive about 18 bedrooms , and there as db's all over the place!!!!!.
However i have found one on the floor where the shower is being install that is supplied by 16mm2 Twin and earth from a 60amp sw fuse. It is a complete run from the switch as i traced it out, doesn't connect to anything other than this board.
Currently it is supplying a cooker and socket radial circuit, cooker is to be disconnected, so i'll be fitting shower in to it.
What i need to know is, as i will be changing the old wylex board to provide RCD protection for the shower. Can i put in a small 4 way with a 63amp RCD Main Sw with a 45amp mcb for shower and 16/20amp for socket radial or does it have to be RCBO's with a main sw, as RCD's cant be used as a main sw??
Thanks in advance..
Thanks in advance..
