shower room extractor and light unit
The only problem is when a break occurs elswhere in the cable or the cable is cut to accomodate some other wiring and the electrician sleeves the wrong strand.
Possible, but should not happen, but possible.
I have been told to de-neutralise black on a three core cables and use grey for neutral (sheathed blue)... using black as cpc (sheathed green/yellow).
Mark
Hi,I have been told to de-neutralise black on a three core cables and use grey for neutral (sheathed blue)... using black as cpc (sheathed green/yellow).
Mark
Do you sheath the uninsulated earth at brown for the switched live?!
This is for a SWA cable, using black as CPC ... as well as making steel armoured off to banjo.
Did i get the wrong end of the stick :)
Mark
