A landlord has purchased a new property and has asked me there are battery smokes installed from. Previous owner but do they need changing to. Mains with battery backup before the new tenants move in or are battery one sufficient
My understanding when I last checked was:-
For a two story dwelling, with a single family renting, smoke alarms are just a preferred recommendation.
If it has more than one family, (i.e. split into flats)..
Or it is a three story dwelling then smoke alarms must be fitted..
Even for non-rental I know three floor properties must have mains powered, battery back-up, interlinked detectors on each floor..
(Interlink can be hard-wired or RF)..
So I cant see how a three-floor rental could require less..
But for bog-standard two floor semi, renting-out mums old house cause she's now in care..
its was a bit vague ??
Unless it has all been updated recently?
:C
AFAIK there aren't any regs in place mandating this and judging by what I see when doing EICR's nobody is checking this
There are building regs that apply to detectors in New-Builds, Extensions, Loft conversions...
But as I said I am not up-to-date with the regulations re rental properties....
But, if you have got some spare time and want to read a loads of bumf you could start trawling the links from the Gov.uk guidance..
https://www.gov.uk/government/publications/smoke-and-carbon-monoxide-alarms-explanatory-booklet-for-landlords/the-smoke-and-carbon-monoxide-alarm-england-regulations-2015-qa-booklet-for-the-private-rented-sector-landlords-and-tenants
Guinness
