Hi All,
Does anyone have or been able to get any definitive information on the " snail trail " issue affecting some solar panels ?
I currently have 575 modules out of 842 showing this problem to varying degrees They were installed in March 2015.
The modules are Renesola JC255M. I have also recently discovered that there is a 250 kW installation locally that was installed by the same company as mine around the same time. When I asked to see their installation they had not noticed that their panels are also riddled with " snail trail".
These are also Renesola JC255s
There appears to be little discernible affect on production thus far that I have noticed.
Renesola seem to have commissioned a report on the" cell finger/ snail trail" phenomenon. Despite claiming there is no effect on production they conclude that there is a 1.28 % degradation after 2000 hrs. It seems that the 2000 hrs is comprised of " extreme" environment conditions that must extrapolate into a longer time period. However it is not at all clear as to what this may or may not be, so the whole thing seems fairly uninformative.
The report implies that " micro cracking" is allowing moisture to penetrate internally and this then leaches the panel components leaving what we see as " snail trails". I cannot interpret this as anything other than a fault with the panel for whatever reason. In addition I also know that moisture and micro circuitry/ electronics do not mix well. Furthermore I am concerned that the problem may eventually affect the inverters i.e. best case scenario- the inverter shuts down or worst case, destroys the inverter. Clearly the inverter issue is me being paranoid at this stage but again with the absence of ANY kind of marking on the other makes of panel ( for info these are 140 Astro energy panels and 16 CSUN panels) I can only conclude that the panels were faulty either on arrival or after installation.
The installer "does not recognise" there is a problem but the manufacturer does not " warrant" any modules displaying " snail trail" as they regard it as caused by an " unpacking issue" - in other words an installation issue. Therefore I basically have over two thirds of my 3 year old panels not covered by any sort of warranty.
Any information or experience of this issue would be most appreciated.
