I am a retired professional electrician who now lives in Denmark. The Danish government has just started a Solar PV grant and I want to install an Grid-tied array. The problem is I do not have any experience installing a Solar system although it seems pretty straight forward. I just need some advice on the design of the optimal solar PV system.
I have been researching the various possibilities and I am currently leaning towards a solar PV system using SMA Sunny Boy 240 Micro Inverters. It appears that there are some big advantages to using Micro Inverters compared to a dedicated single inverter. The main one being that you can monitor each individual panel in the array rather than monitoring the entire array as a whole. (Give you the opportunity to see faulty panels and use various wattage panels in the array should it be required.)
The Danish government requires that the maximum Inverter effect is 6kWh
I would also like add a battery backup for off grid usage, especially has Denmark isn't the sunniest country in the world.
I have based my calculations on the following:
Annual Electricity Consumption (kWh): 4000
Solar Production / Year (kWh): 5300
Expected Personal Consumption: 43%
Electricity Price / kWH (First Year): £ 0.225
Electricity Annual Price Increase: 5%
Electricity Sales Price (1-10 Years): £ 0.09
Electricity Sales Price (11-20 Years): 0
Solar Panel Annual Degradation: 0,50%
Roof Direction: South
Roof Angle: 25˚
I am interested in hearing any design suggestions that you young sparks might have???
Current Considered Design (based on research):
18 x SMA Sunny Boy 240
18 x PanasonicVBHN330SJ47
1 x SMA Multigate
1 x SMA Energy Meter
Can the SMA Multigate read the SMA Energy Meter ( Do they speak to each other?)
What would you recommend as a battery inverter for a 4-6KW battery bank for the above design?
Any improvements or recommendations to this setup?
I can see there is a certain amount of waste converting from the AC provided by the Micro Inverters to DC and back to AC for off grid consumption.
Options 2:
1 x SMA TriPower 6000TL (Any other suggestions?)
What LioN battery solutions would you recommend? Some are seriously expensive but would be interested in hearing your opinions?
I hope you can help an old timer out!
Cheers!
Roof Angle: 25˚
1 x SMA Multigate
Options 2:
Cheers!
