- Nov 28, 2009
- 14,720
- 891
Called to a newish bungalow (completed 2007) New owner just moved in.
He was concerned all the kitchen downlights looked "scorched"
He changed the GU10 halogens for LED's, but one fitting fell apart, that's when he called me.
Yes indeed, in the kitchen there are black scorch marks around all the fittings. I popped the failed one down from the ceiling, and sure enough insulation over the top of the fittings so no wonder they got hot and very bothered.
But the problem, is the one I popped out of the ceiling won't go back. The plasterboard has been so scorched, it's brittle and has crumbled, so there's nothing for the retaining springs to bite on.
I left that one hanging and the owner is going to experiment with various adhesives and sealants, not to stick the light fitting in place, but to try and create a reinforced ring around the crumbling hole that the light fitting will fit into.
Now the perfect solution for this would be cut out the damaged areas, cut in new bits of plasterboard, cut new holes and skim the whole ceiling.
Has anyone had any success trying to patch up such a scorched, crumbling ceiling if so what adhesive / sealant / or other method worked?
