The fire alarm system and all sounder circuits should be designed to fulfil the requirements.Sounders should be installed to alert all persons to the event of a fire, giving them early indication for safe evacuation.
The requirements are clear by definition and that is that the sound level in decibels should be 75, and clearly audible above normal background sound, this may require additional sounders to be installed to comply with this requirement. Fire doors will reduce sound levels, as will insulated wall structures which is why when testing each room is tested for sound pressure.
