yes, just a switchThe photos not good and doesnt blow up enough, is the double pole device from the DNO's meter just a switch ?
Im assuming A rodThe earth in the Henley Block, where does it go at the bottom of the pic ?
...and also protect that little twin that goes to the small consumer unit?So are we just relying on the DNO's fuse to protect the SWA cable then?
yes, its longer than 3mtr (probably more like 25mtr)Thats well done then, presume its longer than 3 meters ?I love the way the armoured and T&E is terminated.
The earths i think are confusing steptoe - and i have to admit its not that clear!
no earth at other end of armour either. installation has its own rod thoughso,apart from the fact there is NO 100mA RCD on the front end and its dog rough terminations,
there is NO other de-facto fault visible.
as I said, the SWA may well be earthed at the other end of the cable.
Im not trying to be twisted, just trying to point out, dont manufacture faults that dont exist.
---------- Post Auto-Merged at 22:17 ---------- Previous post was made at 22:17 ----------
Im assuming A rod
that would be 1.5 (although it does have overload protection by the 6A MCB)yeh looks like 2.5 mm twin protected by poss 80 or 100 1361 fuse mmmm not good lol
no RCD & armour isnt earthed at any point on any cables (although house does have its own rod)so,apart from the fact there is NO 100mA RCD on the front end and its dog rough terminations,
Im assuming A rod
new information comes to lightno earth at other end of armour either
yes it needs protecting,So what about the SWA then
