- Feb 5, 2009
- 5,612
- 1
Ive got a job tomorrow to put a socket in loft for 'gaming room'. Ive found the nearest socket which is a single socket and was going to spur off this socket (if its on the ring) or if its already a spur I was going to change this for a 13a fcu and run the socket from this. I was going to run in 2.5mm from 13a fcu. Would anyone wire this in 1.5mm? The socket is going to be used for PS3/XBOX etc so not that much. The cable will be run in trunking through wardrobes and get up into loft then run in trunking again to socket. All rcd protected and only 3 sockets on this upstairs ring.
Any advice appreciated
Cheers
Cheers
