Hello
I have an existing steel wired armoured cable in my garden that was previously connected to my old garage that is already dismantled. The SWA cable was buried directly into the ground without any conduit. Due to some tree removals and ground excavation, I've had to dig up the cable and will need to bury it again. I'm planning to re-use this cable to power a light and a double socket to a shed that I haven't built yet. I'm in the middle of renovating my garden, so I'm planning to do as much prep work as possible on my own before I hire an electrician to install the light and socket when the shed is ready. So the only thing I'll be doing is bury the cable into the ground and have the end point of the cable next to my new shed or inside it.
I have a couple of questions:
- Is it a legal requirement to have the SWA cable in a conduit before burying it into the ground? Or can I just bury the SWA cable as it is into the ground like how the previous owner had done it? I don't want to bury it without conduit only for the hired electrician to reject the light/socket installation due to this issue. I don't want to lift the cable back up after having paving slabs installed around the shed.
- Is there some legal requirement as how deep I need to bury the cable?
I appreciate your responses.
