Saw this and thought it was worth re posting.... worth taking a couple of minutes and reading all the way. Not a chain letter or anything just a thought for the day.
Enjoy
A lecturer, when explaining stress management to an audience,
raised a glass of water and asked, 'How heavy is this glass of water?'
Answers called out ranged from 20g to 500g.
The lecturer replied, 'The absolute weight doesn't matter.
It depends on how long you try to hold it.
If I hold it for a minute, it's not a problem. If I hold it for an hour, I'll have an ache in my right arm.
If I hold it for a day, you'll have to call an ambulance.
In each case, it's the same weight, but the longer I hold it, the heavier it becomes.'
He continued,
'And that's the way it is with stress management.
If we carry our burdens all the time, sooner or later,
the burden will become increasingly heavy: and we won't be able to carry on.'
'As with the glass of water, you have to put it down for a while and rest before holding it again. When we're refreshed, we can carry on with the burden. So, before you return home tonight, put the burden of work down: don't carry it home. You can pick it up tomorrow.
Whatever burdens you're carrying now,
let them down for a moment if you can.'
So, my friend, Put down anything that may be a burden to you right now. Don't pick it up again until after you've rested a while.
Here are some great ways of dealing with the burdens of life:
* Just accept that, some days, you're the pigeon:
and, some days, you're the statue.
* Always keep your words soft and sweet - , just in case you have to eat them.
* Always wear stuff that will make you look good if you die in the middle of it.
* Drive carefully. It's not only cars that can be "recalled" by their maker.
* If you can't be kind, at least have the decency to be vague.
* If you lend someone
Enjoy
He continued,
